Hi support team,
What is the difference between the roles of "Quiescent current into VIN" and "Quiescent current into VOUT"?
Do they cover different areas?
Dice-K
Hi support team,
Dice-K
Hi Tao,
Thank you for your support.
Is there a way to measure "Quiescent current into VIN" and "Quiescent current into VOUT" using an EVM?
If I simply check the input current at no load, I will get the total input current shown below.
Input current = [IQ_into_VIN] + [IQ_into_VOUT×{VOUT/(VIN×η)}]
IQ_into_VIN: Quiescent current into VIN
IQ_into_VOUT: Quiescent current into VOUT
I want to measure each value, not the total.
Dice-K
Hi Dice,
Please prepare two power supplys for the test, set up as below.
If you want measure quiescent into vin, for example, you want measure the quiescent current into Vin when Vin is 3.6V, then you can set the target Vout at 3V, 3.6Vin and 3.1Vout applied. Then, the output current of 3.6V input power supply is the quiescent current into Vin.
If you want measure quiescent current into Vout, you can apply a lower Vout than Vin, and Vout is always higher than your Vout target of device. then the current into output Pin is the quiescent current into Vout.
Tao
Hi Tao,
Can I assume that by setting the voltage as shown below, the output current of each stabilized power supply will be Iq?
Vin applied voltage: 3.6V
Vout target voltage: 3.0V
Vout applied voltage: 3.1V
Dice-K
Hi Dice,
Yes you are correct, but if you change set-up as below, you'll find the current into Vin and Vout will be very different as you orginal set-up. Most current will flowes into Vout node but not Vin because blocks is power by Vmax which is higher one of Vin or Vout.
Vin applied voltage: 2.5V
Tao
Hi Tao,
Thank you for your reply.
Can the IQ listed in the datasheet be measured with the following settings?
Vin applied voltage: 2.2V
Vout target voltage: 3.3V
Vout applied voltage: 3.4V
If measured with the following settings, does this mean that the proportion of IQ_into_VIN increases and the proportion of IQ_into_VOUT decreases?
Vin applied voltage: 4.0V
Dice-K
