I would like to know whether Output Voltage of driver can be paralleled with FET control to operate 2 different LED strings in which only one turns ON at a time.
5 LED's used in one String. Two strings has cool white & other two strings has warm white LED's.
Either of one color is illuminated at a time. Instead of using 2 separate drivers for 2 set of strings I am looking for cost effective solution.
Attached a snap of schematic to understand in detail. This is a idea popped up if it works I will add diode to LED string for Reverse stand off protection.
