Part Number: UCC28950-Q1
Hi Team...For PSFB Application, I am Planning to Design a Voltage Feedback Circuit followed by Compensator externally and feed that to the either COMP Pin or EA+ Pin.
When Feeding it to the EA+ Pin, EA- Pin and COMP Pin are Shorted to act as a Buffer and One advantage of this way of doing is Soft Start Will be Still Functional.....Does my Understanding Correct? Is it Recommended?
Where as While Feeding the External Compensator Output Directly to COMP Pin, the Soft Start Feature of IC Will be Not Useful and has to be designed externally.....Does this Correct? Is it Recommended?
