Hi team,
When no power supply on BIAS (8 pin), is it allowed to pull up PGOOD with external 3.3V? Any concern on the reverse current flow from PG pin?
Hi team,
Hi Ryoma,
Thanks for reaching out.
You should make sure that you stay within the abs max ratings. In this case, the voltage at PGOOD cannot be higher than Vout+0.3V.
However, when using a pullup resistor with 10k, nothing will be damaged.
Best regards
Moritz
