TPS2052B: Need to know the turn on time
Part Number: TPS2052B
Dear Team,
In TPS2052BDGN when the EN receives the input high what time does it take to give the output.
I wanted this because I am  enabling 2 different IC with same enable so i want the output time required.
Irfan
  • The time it takes to fully turn the FET on is Ton and it is specified as 3ms with an output cap of 100uF and a load of 10 ohms.
    The actual time it takes for the output to reach your target will depend on the load and output capacitance of the system, but 3ms is a good worst case value for system development.
    Chuck
