BQ33100: Do not pull CHG to low
Part Number: BQ33100
Dear team,
We are suffering that CHG-pin do not pulled low and start charging. To understand the behavior, can you please help answer quesitons.
1. Can you tell me how to calculate the R4,5,6,7 to set Charging voltage to specific set voltage?
EVM user guide:
2. Is the evaluation software that works on Win11?
3. Can we set Chg voltage Nom, A, B and max via SMbus command?
If yes, how will be the set value by external resistors? Which is the higher priority?
Yuto
