Other Parts Discussed in Thread: LM5117
Hello I am using LM5117 with switching freq 480KHZin my ECU during Radiated emission in 966KHZ and 160MHZ. When I checked with near field probe I am getting the emissions source is switching node . My voltage input is 28 V and output is 12V , 3A.I tried to reduce switching speed by increasing high side mosfet gate resistor value to 5-10 ohm range but no improvement was observed via near field probe. 3A.Can you please recommend here the snubber in switching node...in case any calculation sheet or any other way to reduce emissions.
