TPS25830A-Q1: Can the output be used to power USB hub IC?
Part Number: TPS25830A-Q1
Let's say the type-C port connected to TPS25830A-Q1 is  only one downstream port of a USB hub IC. Can the output of TPS25830A-Q1 be used to power the hub IC as well as VBUS of the other downstream ports? If yes, then the type-C port connected to TPS25830A-Q1 can be CDP and other ports will be SDP, right?
