Hello.
I'm trying to make a 4kW PFC using UCC28070.
I don't know the function of DB in the image.
Is there a reason why you use it?
If necessary, should the IF value be designed based on the maximum load current amount?
Hello.
Hello Jeon,
Please refer to this previous E2E on the topic: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1077117/ucc28060-what-is-the-role-of-the-bypass-diode
The bypass diode is common to all non-isolated boost-PFC designs, and is independent of the controller.
This diode should be rated to carry the peak inrush current reliably.
It should be a standard recovery diode (not fast recovery) to have a lower forward voltage drop than the boost diode.
Ulrich
