TPS62913: TPS62913RPUR Enable pin
Part Number: TPS62913
I am driving the En pin of TPS62913RPUR from a FPGA output pin. In the FPGA initalisation mode, the output pin will be in the high impedance tri state mode.
If the enable pin is this mode, I would want the TPS62913RPUR to be shut down. would like to check what will the best approach?
Do I need to put in an external pull down resistor or can I make use of the  the EN pin has an active pull-down resistor?
