Other Parts Discussed in Thread: TPS922052,
it is about the D2 (analog dimming) devices, TPS92205xD2.
As i understand it from the datasheet, the analog dimming method is "real" analog dimming.
But the e.g. TPS922052 has analog dimming as a PWM signal beeing converted to an analog voltage internally, so it is a "PWM-to-Analog" (output is not doing PWM, but internal current reference is changed).
In the TPS922052 datasheet, you can find the following sentence at "7.3.5.2 Analog Dimming":
"The TPS92205x family supports analog dimming which regulates [...]"
I assume, that is a datasheet error of the TPS922052, as the analog dimming method of the TPS922050/1 (beein a TPS92205x family?) is different? I would be happy, if the TPS922050D2 has the same analog dimming method as the TPS922052. I would prefer it because of half the package size and lower pin-count.
WM
