Other Parts Discussed in Thread: TPS546C23
I want to synchronize the Master of the evaluation board to an external clock. As a start I tried to pull the SYNC pin to BP3 (through 10k) to make sure it would run freerunning until the sync becomes available. But then I realized it didn't start at all. Then I tried to pull the SYNC to BP6, but the result is still the same. What is the expected behavior here? Is it not possible to power up the device in freerunning mode and switch to external synchronization when the extarnal clock becomes available?
