Some product carry an CTRL or FLK input for LCD gate shaping signal. Are there any examples or actual controllers that have such output or does this signal come from the LCD itself ?
Hi Customer,
Our expert will give you reply later, thanks for the patience.
Hi ,
Yes, CTRL signal comes from timing controller of the LCD panel.
Colin
Thanks a lot. I have worked on many LVDS, MIPI and RGB panels but have not seen such signal suh as FLK. What signal name is normally used general on the LCD panel ? IS there any examples of a panel that support such output signal ?
You can refer to below block diagram.
FLK is conducted from LCD by RST. Now many LCD panel don't need this function no longer.
Colin
