Other Parts Discussed in Thread: TPS2378, LM5116
I'm developing a passthru power management PCBA based on TPS23731 which will be a Class 4 PoE PD device.
The downstream system is a single board computer which already has ethernet isolation magnetics and the PHY.
I'm essentially implementing the reference design of the TPS23731 eval board, but want to omit the isolation magnetics as they are already on the nearby application PCBA and I'm concerned about redundant isolation magnetics causing communication issues.
How can I interface with the upstream PSE using TPS23731 and still adhere to classification etc requirements without isolation magnetics on this power management PCBA?
