Hi Ti Team,
Could you please share the acceptable frequency range for PWM dimming option in LP8865XQDMTRQ1, in addition to the already mentioned minimum pulse width requirement?
Thanks.
Hi Ti Team,
Thanks.
Hi Navinkkumar,
Our expert will reply to you later. Thanks for your patience.
Hi, Navin
Our input PWM signal will directly control the boost output.
But pls confirm that the pull down needs to lower than the EN pull down time to ensure that the device is not disabled.
