Other Parts Discussed in Thread: UCC27624,
Greetings,
I am Sonika, a hardware engineer at Applied Electro Magnetics Pvt. Ltd. As per your suggestion, I replaced the LM5110 IC with its newer version, the UCC27624. However, I am still encountering the same issue—an interface node error.
As mentioned earlier, we are using the gate driver IC (LM5110) along with the digital isolator ISO7420FED. When simulated together, they produce an interface node error, but when simulated individually, they work fine.
Kindly advise on how to resolve this issue.
Sonika
