LM5045: Simulation Issue with LM5045 Circuit & not able to get output
Part Number: LM5045
I am Sonika, a Hardware Engineer at Applied Electro Magnetics Pvt. Ltd. I am currently simulating the LM5045 circuit as provided in the datasheet. However, I am facing an issue where the simulation takes a long time and the output is incorrect—I am unable to achieve the expected 3.3V output, despite using the same component values.
Additionally, I noticed that the example circuit for simulation on your website shows a non-isolated ground. For our application, and also according to the datasheet we require isolation between input and output grounds.
Kindly assist in resolving this issue.
Sonika
