LP5866: How to set 16-bits PWM or 8-bits
Part Number: LP5866
Hi Team,
I can see we can change the PWM duty by setting pwm_bri* regisiter for each dots.
Is there any procedure to set 8-bit or 16-bit? or It's only set pwm_bri*?
e.g. to set L0-CS0 as 8-bits PWM, we need to set only pwm_bri0. For 16-bits, we can use pwm_bri0 and bri1 with no other register change.
Kotaro Yamashita
  • Hi Kotaro,
    Yes, the 8-bits or 16-bits mode is selected through setting the data_ref_mode registers. The mode definition is also attached for your reference.
    I suggest to have a call if you need more detailed procedure.
    Felix
