TPS50601A-SP: 7V input and 5V output
Part Number: TPS50601A-SP
Could you please help me with some ideas? In our previous designs, we have successfully used the TPS50601A to generate output voltages ranging from 1V to 3.3V, with a 5V input. Currently, we are facing new constraints that require us to use a 7V input and obtain a 5V output.
According to the datasheet, the device supports input voltages between 3V and 7V. However, we would appreciate your guidance on whether this configuration—specifically using a 7V input to achieve a 5V output—is considered reliable for long-term operation.
Any insights or recommendations you could provide would be greatly appreciated.
Vlad
