TPS4800-Q1: SRC configuration question
Part Number: TPS4800-Q1
Other Parts Discussed in Thread: TPS4810-Q1
Hi expert,
My customer (CosMX) is evaluating TPS4800-Q1 and they want to know if the SRC can be connected to external FET Source when R&D uses low side current sensing like below TPS4810-Q1 circuit shows?
Customer noticed that the Figure 7-7 in datasheet shows the SRC is connected to FET Drain with low side sensing configuration:
Ryker
  • Hi Ryker,
    This looks to be a bad image. The SRC should always be connected to the FET SRC. Looks like the image was intended to have only one FET not b2b.  I will submit a ticket to make sure its reported and updated.
    Sarah
