Part Number: TPSM82866A
Other Parts Discussed in Thread: TPSM82823A, , TPSM8287A06, TPSM82866C
Hi, could you clarify how the VOS pin should be connected and what its function is vs FB?
Looking through the datasheets of a few similar part- TPSM82866A and TPSM82823A and it says to connect after inductor or at the output cap, depending on which one I look at.
Is the intent there to use it as a single ended remote sense, and if so, shouldn't it be connected to the load?
(Planning to use TPSM82866AA0PRCFR in a somewhat low voltage/high current application (0.75V 4-5A) and am concerned with the voltage drop)
Thanks!
