The GPC tool always returns an empty report. I think my data is correct and I'm not getting any errors. I'm using the following input data;
Is there an expection when this is finished? I'm currently blocked with calibrating my packs. Or is there any way you can run the tool?
The problem with this data-set was caused but a time-value dropping to a very small value in one point, resulting in negative time estimate during discharge. Tool is now improved to automatically detect and remove such points, so try to re-submit to observe successful return.
However, even after successful run all the chem IDs have >3% DOD error, so new chem ID will need to be released to support this cell.
Yes Tool is working again indeed. Thank you!
I did notice the 'New chem ID needs to be released for this cell. Please contact your TI representative to send the cell to Dallas for characterization'. Since I don't have TI representative yet, how do I get a new chemID?
Hi Yevgen,
It looks like my GPC report still returns zero. I just tried it again. Could you please check it for me? I attached my zip file.
Thank you
Jiaqi
