Other Parts Discussed in Thread: LM74930,
Hi Texas team members:
ISSUE: We has a project using LM74930-Q1, in voltage jump test from 14volts to 19volts, we find that HGATE tend to low, FLT goes to low, output voltage dropped off. And the in 1 second, the IC LM74930 return to normal automatically.
Design: see the schematic drawing as above.
Analysis: I guess it is caused by over voltage, so I removed R12814 and R 12817. no any change for the issue. Then I short the R ILIM to GND for over current concern, but there is no change.
Question: what's the cause for the fault?
