Per the datasheet electrical characteristics table, the adjust current is specified as +3uA typical at room temp to +15uA maximum limit over temperature. Footnote (10) also says "(10) ADJ pin bias current flows into the ADJ pin."
Does this mean the adjust current can only go in one direction, i.e., into the ADJ pin? The adjust current cannot flow out of the ADJ pin?
