For a half-bridge using the UCC27201ADR, should the VSS pin connect directly to the low-side MOSFET source power ground (PGND), or can it share the logic ground via a single star-point tie?
Hi Ahmet,
You can share VSS with logic ground and low-side power ground.
Rubas
