This question is related to following question.
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1458265/tps562201-datasheet-change?tisearch=e2e-sitesearch&keymatch=TPS562201#
I asked following question but we need to confirm more detail to explain.
>1. Why did you change "Fsw" conditon from "Vin=12V, Vo = 1.05V, FCCM mode" to "Vin=12V, Vo=3.3V, Io=1A" in datasheet Rev D ?
>2. Why did you change some figures which is described in section 5.6 in datasheet Rev D ?
>3. Why did you change sentence of section "Normal operation" in datasheet Rev D ?
Could you reconfirm and give comment about following detailed question ?
Q1. I understood that you added new fab which apply LBC9.
What I would like to confirm is why "the process change" change the fsw measurement conditions.
Could you please explain the reason ?
Q2. Why were figure 5-1 and figure 5-2 changed ?
Is specification improved because of "design change" ?
