Other Parts Discussed in Thread: BQ76907
I wanted to enquire how do we overwrite calibration values present in the data memory of the device?
Kindly refer the following statement from TRM :
If the host does not overwrite values for the calibration gain or offset configurations, the BQ76907 device uses the factory trim values stored in OTP for each respective setting. When a calibration configuration value is written, the device uses that in place of the respective factory trim value.
I want to know the method to overwrite calibrations if we do not want to use factory trim values? Is it via OTP? If so, can I as host make changes to the same?
Thanks for your support in advance.
