TPS7A4701-EP: Current limiting capability
Part Number: TPS7A4701-EP
Other Parts Discussed in Thread: LM117
Hi all
Could the NR pin be used to effect a current limit on the output, i.e. could you use an NPN transistor to pull this pin low and so lower the output voltage from a control loop sensing the input current to IN pin?
Br
Edba
