I wanted to use this part for CC-CV converting. I used same schematic config as in datasheet (my schematic below) but IC seems not to be active. As if it is in shutdown mode. When I measure gate pin of PFET with osciloscobe I only see a flat high voltage. It is not trying to drive the fet. What can be the problem? What am I missing? I tried various changes but no result. Thanks in advance.
