About using the LM51770 circuit there's a question.
If the SYNC pin I provide a valid frequency from other ic.
I see the data sheet there's mentioned If a signal within the recommended range on the SYNC pin is applied, the device does not enter uSleep mode.
Is there any side effect when I applied SYNC a valid frequency from other ic and the selected to PSM?
