Other Parts Discussed in Thread: BQ25713,
您好,我目前正在使用贵公司的 TPS25751+BQ25713 解决方案进行充放电管理。我之前曾向贵公司寻求有关如何实现给电池充电的技术支持。此问题已解决。但现在我遇到了一个新的问题。我应该如何配置,才能使充电管理不仅可以给电池充电,还可以同时通过 TYPE-C 接口对外供电
Hi Zixiong,
Translation: Hi, I am currently using your company's TPS25751+BQ25713 solution for charge-discharge management. I have previously approached your company for technical support on how to charge the battery. This issue has been resolved. But now I have a new problem. How should I configure so that the charge management can not only charge the battery, but also power the battery externally through the TYPE-C interface at the same time
What is the difference between "charging the battery" and "Powering the battery externally through the Type-C interface"? They sound like the same thing to me and I'm not sure how they would differ.
Thanks and Regards,
Chris
