Hi Vivian,
i can not sent message in the previous block,so I build this new block
1 This problem only happen on V phase (only top IGBT but not bottom)
2 we have done the ABA swap ,this problem still happened even we change this driver to a new one
I find the layout is bad, the trace between VDD and COM is long , does it cause the problem? If not ,can you give me more analysis? Thank you!
best wishes!
