Hello team,
Do we have layout guideline/example for 2 layer PCB?
Shotaro
Hello team,
Shotaro
Hi Shotaro-san,
Please refer section 7 for all the Layout related documentation. FYI, it is highly recommended to use 4-layer board for better thermals.
Collection of TI Buck App Notes.pdf
Gautam
Hi Gautam-san,
The customer's design uses 2 layer PCB. This is the reason why I am posting to E2E. Can you tell me specific recommendation? TPSM861252 is a module.
Shotaro
Shotaro-san, we don't have anything specific documented for 2-layer as suggestion is wrt 4-layer only. We can review Customer's layout if required.
Hi Gautam-san,
I checked EVM layout. I think "Inner1 Layer" and "Inner2 Layer" are just prepared for thermal management. And even if there is no both layers, the DC/DC module works. Is it not correct?
https://www.ti.com/jp/lit/ug/sluucy0a/sluucy0a.pdf
Shotaro
Yes, you're right. Hence I mentioned earlier "for better thermals". Rest of the layout guidelines are anyways documented under: 8.4.1 Layout Guidelines of datasheet; which is good enough.
Gautam
