TPS628503-Q1: Minimum On-time of Low-side FET
Part Number: TPS628503-Q1
Hi team,
My customer Bosch are using TPS628503-Q1for their project, and they have questions about the spec of Minimum on-time of low-side FET.
Datasheet provide the typ. value only, they asked if we can provide the maximum value? If not, please feedback the explanation. Thank you
Xiaowei Zhang
  • Hello Xiaowei,
    It is not characterized but I feel it should not be important to customer. As LS FET operates primarily to ensure continuous inductor current during off time and it is adjusted by controller and is not a limiting parameter for output voltage regulation duty cycle or switching behavior. As this parameter does not affect external design constraints. Typical value is for informational purpose.
    Farheen
