Hii Team,
We are in Requirement of CE Certification details for the below parts, please provide info on this
TPS62290DRVT
TPS73701DRBR
TPS62291DRV
SN74LVC1G34DSFR
Karthik
Hii Team,
TPS62290DRVT
TPS73701DRBR
TPS62291DRV
SN74LVC1G34DSFR
Karthik
Hi Karthik,
Can you please clarify which documentation/certification you need?
Company-level statements can be found under: https://www.ti.com/support-quality/environmental-info/environmental-home.html
Thanks!
Yann
Hii Yann,
Can you please let me know if the listed components were UL or CE Certified?
Karthik
Hi Karthik,
I can only reply for TPS62290DRVT and TPS62291DRV. Please start a separate thread for the remaining devices, in order that your question can be assigned to the responsible team.
Plastic encapsulating materials used in TI semiconductor products meet the requirements of UL 94 flame classification V-0 (unless stated otherwise on the product datasheet.) For TPS62290DRVT and TPS62291DRV, I can confirm that UL 94 flame classification V-0 is met.
The EU Declaration of Conformity (DoC) is available for the TPS6229X evaluation module TPS62290EVM-279: https://www.ti.com/lit/cr/sszqkw7/sszqkw7.pdf
I hope this helps.
Thanks!
Yann
Hii Yann,
Apart from Plastic encapsulating materials used, does the internal circuitry of the IC UL Certified?
Karthik
Hi Karthik,
No, this device has no other UL certification apart from flammability.
Thanks and best regards
Yann
You're welcome. I will close the post now, feel free to get back to me in case of further support needs.
Thanks!
Yann
