BQ27441-G1: Battery charger application design
Part Number: BQ27441-G1
Other Parts Discussed in Thread: BQ24072T,
I am developing a battery charger application using lithium-ion batteries.
In past designs, I used the BQ24072T.
For new board designs, I am considering adding a fuel gauge IC to more accurately determine the remaining battery charge.
I am considering using the BQ27441-G1 as the fuel gauge IC.
In this case, the battery has only one thermistor, so it is not possible to measure the temperature with both the charger IC and the fuel gauge.
Is it possible to configure a circuit that avoids this?
Also, could you recommend an IC that combines a battery charger IC and a fuel gauge?
