TLV62569: Will nearby strong magnet affect converter operation?
Part Number: TLV62569
Hi TI team,
I am using the TLV62569 in my design, and there will be a strong permanent magnet placed near the module due to mechanical constraints.
I have few questions:
1.Will the external magnetic field affect the inductor and cause abnormal converter behavior?
2. If yes, how can I determine the safe minimum distance between the magnet and the inductor ?
Thanks for your support!
Tom
  • Hello Tom,
    What application are we talking about?
    Do you have a layout to share?
    Febin
  • Hi Febin,
    Thank you for your reply.
    The application is a keyboard that uses magnets for attachment. I can provide you with the schematic, layout, and specifications of the strong magnets. However, due to the sensitivity of the information, is there a way I can share it with you privately?
    Thanks!
  • Hello Tom,
    In my opinion, having a strong magnet close to the inductor will be a problem. Since this is not a typical use-case, we do not specify any safety distance and this is also not a tested scenario. I would suggest to keep it as far as possible from the inductor.
    Please share your email ID for further discussion.
    Febin
