TPS709: schmatic review
Part Number: TPS709
Would you have any suggestions for modifications to the schematic?
  • Hello Sky,
    Looking through your circuit, everything looks good as per the datasheet. The datasheet does not explicitly specify what value your Cin must be but in section 8.1.1 it does say it is recommended from a range of 0.1uF-2.22uF. Your Cin is greater than 10uF.
    Abraham Benzaquen
