TPS53688: VCCIO Termination - if SVID is unused
Part Number: TPS53688
Dear TI Forum,
in a TPS53688 design, which uses only PMBus and Channel A. What is the correct termination for VCCIO?
The PMBus uses a supply which is always on and not VCC of the controller.
SV_CLK and SV_DIO are connected to GND and SV_Alert is open, as per datasheet request.
Should I connect VCCIO via 10k to one of the two supplies (preferred VCC)?
Thank you.
Kind regards
Moritz
