LM5117 (ECS-DC-H5117) what this line in the datasheet means?
Because in the AN-2103 EVB I didn’t saw we did this
Hello Ohad,
You can connect this to the DAP and connect to the GND plane through VIAs. Make sure the VCC cap, GND side connects directly to this pin.
the CSG is the pin that connects directly to the RENSE Negative and should not be connected to the DAP.
Hope this helps.
David.
