Following questions came up for the customer Marquardt when designing in our BQ79758-Q1. Find customer schematics attached if needed.
1,what’s the different between bq79758 and bq79758B?
2,we want use bq79758 over current protect to switch mosfet quickly, did you have reference design for this?
3, Do you have a test report for OC function? How long does it take until the mos is disconnected when an overcurrent is detected?
4,OC output is only in GPIO4?
5,Gpio 10,GP1011,can’t find it in pin data sheet,, could you help to check?
