I am using TPS25730DREFR with power supply only from VBUS_IN. I plan to use the LDO_3V3 pin to drive the ADC voltage divider resistor, /FAULT_IN pull-up, CAP_MIS LED, and external communication signal pull-up. Therefore, I would like to know how much current can be drawn from LDO_3V3 when VBUS is at 5-20 V.
