Other Parts Discussed in Thread: TPS56837H
Hello:
The current customer requires a synchronous switch buck converter that supports multiple output fast charging protocols, supports USB-C interface, PD3.1/PPS protocol, and does not require an I2C interface. The input voltage range is 7V-32V, and the output voltage range is 3.3V-21V. Please help recommend, thank you!!!
I have already consulted about this issue on another thread,see below
TPS25751: TI recommendation - Power management forum - Power management - TI E2E support forums
