BQ25751: How should the pin ACDRV be set if it is not in use
Part Number: BQ25751
We use 13 batteries to make a buck-boost charger that can charge and discharge, and has I2C communication. If the back-to-back INPUT tube is not used or replaced with a single tube, how should the ACDRV be set? The ACDRV pin drives the MOS. Besides the specification sheet stating that it will turn off when input voltage is detected, can we set it to turn off ourselves?
