UCD3138: cannot build the program
Part Number: UCD3138
I use CCS 6.1.3.00033, arm compiler 5.2.4. It seems hard to build the program downloaded from ti UCD3138_FW_SDK.
  • Hello Gudong,
    I do not think I have enough information to help you much. Were you able to successfully build eventually or does the build never finish? Are you able to try building another UCD project besides the LLC HB firmware? Are you able to build firmware from other TI products, such as C2000 projects? Are you header and linker files correctly linked to the project?
    You can find example C2000 projects on the TI Resource Explorer: https://dev.ti.com/tirex/explore
    Jonathan Wong
