I’ve created a USB 2.0 circuit as shown in the diagram, using the TPS2051B for overcurrent protection.
In many reference designs, the *OC (Overcurrent) signal is connected to another device, which then drives the EN (Enable) pin. However, in my design, I’ve directly connected the open-drain *OC signal to the EN pin.
Is there any issue or drawback with this approach?
