hi ,
our ctm want to use the UCD9222, but can't find the programmer or download line infor. can you help to give some infor about it? or send to me by email: qing.gao@avnet.com. thanks!
hi ,
Do they want to configure the device themselves or do they want Avnet to load the configuration for them prior to receiving and installing the device?
Avnet has been pre-configuring controllers for a number of customers for awhile now using System General programmers.
A list of programmers which support either Gang Programming or are tested for JTAG system compatibility can be found in the Configuration Programming for UCD Devices document available from the Help & Documentation Center within the Fusion Digital Power Designer software under the UCD92xx tab.
Do we have a board to offer to a customer so they can drop in their devices and program them? Or they only can use the programmers listed in the above document?
Thanks for your help.
Most customers load the UCD92xx configuration after the deviec has been assembly onto their system boards, all the configuration methods are listed in the document referenced previously..
TI does not offer programming boards that support package level configuration of UCD92xx devices prior to assembly, several customers have designed their own but of those customers that don't load the configuration after assembly most get their controllers pre-configured from a distributor.
