My input range 20-31V and I need 24V. What is the peak efficiency and how do I set it to output 24V ?
Thank you
Thank you
I would like to draw you attention that this device is a buck converter. You will not be able to get 24V when the input voltage is 20V. Hope you get my point. Let me know if I am mistaking something.
Pramanik Patel
Yes agree, my worst case is 20V, nominal is around 26V
Do you recommend any converter (maybe a buck boost) in this range and can output 24V ?
Thank you
Thanks for the reply. Then you mean to say that input voltage may drop to 20V only for a very short period of time, right?
Pramanik Patel
Not really, during worst case operations I will see 20V and the buck-boost should still output 24V rail for bias power. I have found a Vicor module that can do this. Does TI have anything similar that can do this ?
Vicor input range 9V-60V and outputs 24V
Thank you
It is for sure that only buck may not work. I will have to look into for a device that support such kind of operation.
Pramanik Patel
Hi Pramanik,
Please let me know if you have any device with the capabilities. So far I found only a Vicor module that can do that.
Vin range 20 to 60V and out 24V and isolated buck-boost converter.
Thank you
Please clarify the following:
1) Let say if Vin < 24V then the device must work as boost
2) Let say Vin > 24V then the device must work as buck
So we need a device capable of changing it's topology according to Vin?
Pramanik
Yes, it should be a buck boost converter.
For an example PRC60-48-S24 does that for you.
Do you have a similar part ?
Thank you
Thanks for the reply. I am out of office till 25/08/2025. I will still look into, but I would advice to please contact Boost team, since Ideal with buck converters.
Pramanik Patel
