Hi team,
Is the PMBus address determined only at power-on (POR)?
Is the address also reset when a RESET input is applied?
Hi team,
Hi yihe,
Is it possible to change the address by switching the resistor value of ADDR0/1 and inputting RESET?
Hi Yihe,
I am considering the attached configuration.
If the PMBus address is set when RESET is released, is it okay to supply the sequencer and multiplexer from the same power supply?
The address is only set when the power is turned on, it does not change dynamically.
