Dear Texas Instruments Support Team,
I am currently designing a circuit using your TPS22950 load switch and would like to confirm some details regarding the ILIM pin.
To properly select the resistor (RILIM) connected to the ILIM pin, I need to understand the amount of current that flows through this pin. However, I could not find specific information about the ILIM pin current in the datasheet.
Could you please provide clarification on the following points?
- What is the typical and maximum current that flows through the ILIM pin (i.e., the internal current source value)?
- What is the expected power dissipation across the RILIM resistor, and what power rating would you recommend for safe operation?
Your assistance would be greatly appreciated. Thank you for your support.
